914 smog testing, Whats required in your area? |
JeffBowlsby |
May 26 2016, 09:44 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I had to smog my DD today and noticed this sign in the waiting room, which would be applicable to the 1976 914s. Tech says they pinch off the evap system (tubing and charcoal filter between the fuel tank and air filter box) and insert some kind of gas under low pressure to test the evap system, for leaks.
What other testing is required in your area, if any? Attached thumbnail(s) |
76-914 |
May 26 2016, 10:25 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,498 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Are you sure they require yours to be tested? It does say "most model years".
ConeDodger |
May 26 2016, 11:10 PM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Lo-Fi Version | Time is now: 13th May 2024 - 05:36 AM |
