914 smog testing, Whats required in your area? |
JeffBowlsby |
May 26 2016, 09:44 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I had to smog my DD today and noticed this sign in the waiting room, which would be applicable to the 1976 914s. Tech says they pinch off the evap system (tubing and charcoal filter between the fuel tank and air filter box) and insert some kind of gas under low pressure to test the evap system, for leaks.
What other testing is required in your area, if any? Attached thumbnail(s) |
somd914 |
May 27 2016, 10:54 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
In Maryland the Baltimore and DC areas require smog checks every two years, I'm just outside the limit but given the growth of this area it's just a matter of time before my area will require checks. Don't know details of what all they check.
But historic cars are exempt - registered as a historic thus limited usage, presently 20+ yrs old though MD has been contemplating 25 years as the starting point. So when it reaches my area the Porsches will be exempt. |
Lo-Fi Version | Time is now: 12th May 2024 - 09:27 PM |
