914 smog testing, Whats required in your area? |
JeffBowlsby |
May 26 2016, 09:44 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I had to smog my DD today and noticed this sign in the waiting room, which would be applicable to the 1976 914s. Tech says they pinch off the evap system (tubing and charcoal filter between the fuel tank and air filter box) and insert some kind of gas under low pressure to test the evap system, for leaks.
What other testing is required in your area, if any? Attached thumbnail(s) |
Dominic |
May 28 2016, 09:59 AM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Jeff,
I never knew that test existed either. The only car I have that fits in that category is my 82' VW Rabbit Pick-up, it passed smog with no issues, the tech looked at the evap system hoses to ensure they matched the diagram on the sticker under the hood and tested my gas cap. What else does this test encompass? I also had my 2013 VW Passat TDi "Smog Tested" which means they hook up to your OBD II port to see if anyone installed any aftermarket software. No tailpipe testing. Cheers, Dominic |
Lo-Fi Version | Time is now: 13th May 2024 - 09:10 AM |
