914 smog testing, Whats required in your area? |
JeffBowlsby |
May 26 2016, 09:44 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I had to smog my DD today and noticed this sign in the waiting room, which would be applicable to the 1976 914s. Tech says they pinch off the evap system (tubing and charcoal filter between the fuel tank and air filter box) and insert some kind of gas under low pressure to test the evap system, for leaks.
What other testing is required in your area, if any? Attached thumbnail(s) |
ConeDodger |
May 28 2016, 11:08 AM
Apex killer! Group: Members Posts: 23,583 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Just talked to my tech. The 76 2.0 and 1.8 both require a test of the evaporative system. How this works is like this: a gas cap adapter is put in place of your own gas cap. A small amount of pressure, 2psi of nitrogen gas is applied to the tank and the decision of pass/fail is based on the system holding that pressure. As for damaging your car, it would have to be pretty fragile for 2psi to damage anything.
Lo-Fi Version | Time is now: 12th May 2024 - 06:15 PM |
