Nylon shifter bushing lubrication, Inside the side shift ball and socket |
jack20 |
May 28 2016, 12:22 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
What is the appropriate lube to on the nylon (I assume nylon) bushings?
Is lithium grease OK? |
May 28 2016, 12:36 PM
914-6 GT in waiting Group: Members Posts: 19,237 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes
jack20 |
May 28 2016, 12:38 PM
Thank you!
forrestkhaag |
May 28 2016, 12:39 PM
Works for me without any deterioration or appreciable wear on the mating surfaces. My side shift went in about 8K ago and on daily use, no visible wear and a good slide fit.
The drive-train is out for a couple of days while i install a new head in the place of a one-in and one-out spark plug pop-out conversion that was bestowed upon my ride out of the blew... (IMG:style_emoticons/default/WTF.gif) So i had a good opportunity to inspect the linkage bushings.... Oh well. I wanted to clean up the dust from the resent 1850 mile AZ desert run in the engine compartment, change my fuel filter and get a couple of things ready for my distant future 3.0 SC to move in. (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Lo-Fi Version | Time is now: 24th April 2024 - 05:02 PM |
