suby engine and megjolt - what single carb? |
jimkelly |
May 28 2016, 12:32 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I was thinking maybe a Harley 40mm carb might work?
I figure a motorcycle type carb and be used in place of the throttle body? I have a few suby ej22 engines and thought i would fool around with carburation and with using stock ecu/fi too. http://www.randakksblog.com/single-carb-conversions/ Attached image(s) |
Mike Bellis |
May 28 2016, 12:46 PM
Would work like a Pinto carb on a T4 motor... (IMG:style_emoticons/default/barf.gif)
mgp4591 |
May 28 2016, 01:03 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Exactly - why would you go carb when FI is the real solution?? (IMG:style_emoticons/default/blink.gif) |
jimkelly |
May 28 2016, 01:14 PM
I plan to use a suby engine and trans and its FI in my 1975 car. but i have an extra engine and thought it would interesting to see what a single carb and megajolt can do on a ej22. I am not expecting a carb to be better or even very competitive to FI but the engine should run somewhat decently as does a type4 with single carb does.
https://www.youtube.com/watch?v=3MFdcY-DqqI |
76-914 |
May 28 2016, 09:44 PM
No comment! (IMG:style_emoticons/default/slap.gif)
rightpedal |
May 29 2016, 05:47 AM
rightpeda; Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
Jim this might be one of those situations where the voices in your head are not speaking in your best interest. (IMG:style_emoticons/default/biggrin.gif)
BTW I am installing the 3.0 today should have your mounts back to you later this week. thanks |
DBCooper |
May 29 2016, 08:29 AM
I'm afraid you'd be getting yourself into quite a lot of work just to achieve mediocrity. Carbs work, of course, but a single carb with long unheated runners isn't usually a very good idea. So if you're going to build the MegaJolt why not take it a step further, keep it F.I. and just build a full Megasquirt? No fabrication that way, it's almost plug-and-play, and since you wouldn't need to buy a carb and adapt it the cost should probably be about the same. But if you just HAVE to have carbs then why not two?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i53.photobucket.com-2618-1464532174.1.jpg) |
Chris914n6 |
May 29 2016, 11:51 AM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Stock TB is 60mm or so right?
Sounds like a bunch of time for half the HP. |
jimkelly |
May 29 2016, 11:59 AM
I hear you (IMG:style_emoticons/default/smile.gif)
good thread on dual carbed suby in vw bug http://shoptalkforums.com/viewtopic.php?t=132524 |
jimkelly |
May 29 2016, 12:14 PM
at work I have 2 ej22's under my desk ($100 each). I have one more in my 1990 legacy 5spd awd parts car ($475) there that has at least one cylinder of bad compression, that I will pull engine and trans this week and get on a stand to start putting stock FI on it. and I have an almost driveable 1990 legacy awd auto ($250).
I went on a binge buying streak of legacy's and ej22 recently. about to delve into FIing them, one at a time. Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 02:13 PM |
