Plug in needed to see the tire size calculator |
bandjoey |
May 29 2016, 07:09 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
ON Waterfox and Edge I can't see the tire size calculator. Message says 'Need a Plug In' but it doesn't say which one.
Help? Which One? Thanks |
porschetub |
May 30 2016, 01:04 AM
ON Waterfox and Edge I can't see the tire size calculator. Message says 'Need a Plug In' but it doesn't say which one. Help? Which One? Thanks Google works for me (IMG:style_emoticons/default/smile.gif) |
bandjoey |
May 30 2016, 12:48 PM
I know. I know. There are other calculators out there. But using the Official 914 Calculator. What's not to trust ?? (IMG:style_emoticons/default/flag.gif)
Tom_T |
May 30 2016, 04:43 PM
I know. I know. There are other calculators out there. But using the Official 914 Calculator. What's not to trust ?? (IMG:style_emoticons/default/flag.gif) Hey Bill, IIRC the 914 calculator hasn't worked for a few years now due to some problem with the plug-in. Try one of these, & use 165/80R15 as the baseline 914 tire size.... https://www.tacomaworld.com/tirecalc http://www.discounttire.com/dtcs/infoTireMath.do http://www.1010tires.com/Tools/Tire-Size-Calculator https://tiresize.com/ (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/flag.gif) Tom /////// |
bandjoey |
May 30 2016, 05:22 PM
Thanks Tom!
pvollma |
May 30 2016, 07:41 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
ON Waterfox and Edge I can't see the tire size calculator. Message says 'Need a Plug In' but it doesn't say which one. Help? Which One? Thanks I wrote this one years ago, it already has the 914 gear set available in the pulldown menu, and produces a chart of speeds in each gear. It requires the Java plugin. There is a help page available to explain how to use it. Gear and Tire Calculator |
May 30 2016, 08:55 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hey Bill, IIRC the 914 calculator hasn't worked for a few years now due to some problem with the plug-in. (IMG:style_emoticons/default/WTF.gif) The 914 tire size calculator works just fine and has for the last 15 years or so. (IMG:style_emoticons/default/poke.gif) Since it hasn't been updated in forever, some browsers will complain but you can still add an exception for 914world and it will run just fine. It uses Java, so make sure you have the latest version installed. Then go to your Java control panel and under "Security" add: http://www.914world.com to the "Exception Site List" Restart your browser and it should prompt you to run the applet the next time you go to the page. (IMG:style_emoticons/default/shades.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th May 2024 - 12:34 PM |
