Couple of newbie questions, Wheels and arches |
evvo |
May 30 2016, 08:19 AM
Newbie Group: Members Posts: 6 Joined: 22-May 16 From: Walsall Member No.: 20,029 Region Association: England |
Sure these have been asked a thousand Times before. I've tried the search thread but keep getting people's build threads that I lose myself in for a couple of hours (IMG:style_emoticons/default/smile.gif)
Ok question one. What are the largest width of wheel that will fit under standard arches? Also my car is a 1.7 which I want to upgrade. I grew up in a family that all had old beetles and my first car was a beetle with a 1.6 twin choke carb. Am I better to upgrade the 1.7 or go for something bigger. The cars only going to be a fair weather car here in the UK. Thanks Chris |
Mikey914 |
May 30 2016, 08:27 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just drive it. If you want to upgrade, get a core motor and build it. That way you are not missing drive time.
1.7 isn't too bad motor but into the quest for speed, just built what you want, them it will just be a quick swap, and you have a spare motor if you ever need one. |
evvo |
May 30 2016, 09:16 AM
Just drive it. If you want to upgrade, get a core motor and build it. That way you are not missing drive time. 1.7 isn't too bad motor but into the quest for speed, just built what you want, them it will just be a quick swap, and you have a spare motor if you ever need one. Thanks. I'm not looking for loads of power our roads are mostly twisty apart from the motorways I'll see how I go with the 1.7 first like you say. Anyone got an answer to the wheel question? |
Coondog |
May 30 2016, 09:55 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
165 to 205
era vulgaris |
May 30 2016, 10:21 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Anyone got an answer to the wheel question? Depends on the offset. But if we're talking 5 lug Fuchs for example, 6" wide will fit with no modification. 7" wide may or may not fit. I'm running 15x7 Fuchs on my stock fender car, but the rear fenders had to be pulled a little to prevent rubbing. |
May 30 2016, 10:42 AM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
165 to 205 (IMG:style_emoticons/default/agree.gif) 5.5"/6" wheel with the right offset. 7" is pushing it and you probably need to roll the fenders. Anything over 205 most certainly requires rolling the fender lip or fenders. But again, there are so many different 4-lug wheels out there, you really need to make sure the offset is correct for the 914. A lot of the available wheels were designed for the bug and don't have the best offset for our cars. I personally like the 4-lug Fuchs with 195 or 205 tires. To me, they are a perfect fit for a stock 914. (IMG:style_emoticons/default/smile.gif) |
porschetub |
May 30 2016, 02:08 PM
Sure these have been asked a thousand Times before. I've tried the search thread but keep getting people's build threads that I lose myself in for a couple of hours (IMG:style_emoticons/default/smile.gif) Ok question one. What are the largest width of wheel that will fit under standard arches? Also my car is a 1.7 which I want to upgrade. I grew up in a family that all had old beetles and my first car was a beetle with a 1.6 twin choke carb. Am I better to upgrade the 1.7 or go for something bigger. The cars only going to be a fair weather car here in the UK. Thanks Chris Yes 205 is sensible and provides a good amount rubber on the road,you live in the land of the Minilite wheel,IMO these are one of the nicest looking aftermarket wheels around. Haven't checked their website but I would say they would stock a wheel with the correct offset for your car. |
evvo |
May 31 2016, 03:39 AM
Cheers guys so 15x7 et23.3 should be bang on?
I was thinking of going to image wheels who are local to me and been making wheels for years. http://www.imagewheels.co.uk |
Mueller |
May 31 2016, 08:14 AM
Cheers guys so 15x7 et23.3 should be bang on? I was thinking of going to image wheels who are local to me and been making wheels for years. http://www.imagewheels.co.uk Yes and no....fits the front fine, will rub in the back for sure if totally stock fender wells. Need a higher number in the back. |
evvo |
Jun 2 2016, 11:12 AM
Thanks for the info guys (IMG:style_emoticons/default/beerchug.gif)
SixerJ |
Jun 2 2016, 03:36 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
I used to run 15x195x65 and had them on both deep sixes and the flat replica sixes in the picture on my old slab sided 1.8
To me they were a great balance of grip in the dry and just enough fun in the wet to break away / be very controllable with rather the underpowered engine I also agree with others enjoy it for the summer. Have a think about what you want to do and maybe build a hotter engine up ready to do a swap (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 9th May 2024 - 04:14 AM |
