Another stupid question, Instrument gauges |
RacingDreamz |
May 30 2016, 07:57 PM
Member Group: Members Posts: 62 Joined: 21-May 15 From: Mountain City, Tn. Member No.: 18,747 Region Association: South East States |
I know this is a very stupid question and I should be flogged for it but I have to ask. I've been out of the VW business or owned one in a very long time. I just got my 73 1.7L going today. Finally got it started and running.
On the instrument gauges, when first started, the "G" gauge light was flashing as well as the larger 'red' "B" light. Can anyone tell me what these are? When we first started the car, the G light was on. We found a return fuel line leak and fixed that. Then the G light was off. But the B stayed flashing. The car has been sitting for 8 years if this helps. Thanks in advance. |
Steve |
May 30 2016, 08:17 PM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I know this is a very stupid question and I should be flogged for it but I have to ask. I've been out of the VW business or owned one in a very long time. I just got my 73 1.7L going today. Finally got it started and running. On the instrument gauges, when first started, the "G" gauge light was flashing as well as the larger 'red' "B" light. Can anyone tell me what these are? When we first started the car, the G light was on. We found a return fuel line leak and fixed that. Then the G light was off. But the B stayed flashing. The car has been sitting for 8 years if this helps. Thanks in advance. The "G" is the alternator light. It goes off after you rev the engine. "B" is the brake light. If you release the emergency brake it should go off. It it doesn't it could be the reset button on the side of the master cylinder. This button is accessible behind the front left tire. Have you bleed the brakes lately or replaced the master cylinder? Either one of these could cause the brake light to flash even after the emergency brake is off, until you push the reset switch. |
RacingDreamz |
May 30 2016, 11:32 PM
I know this is a very stupid question and I should be flogged for it but I have to ask. I've been out of the VW business or owned one in a very long time. I just got my 73 1.7L going today. Finally got it started and running. On the instrument gauges, when first started, the "G" gauge light was flashing as well as the larger 'red' "B" light. Can anyone tell me what these are? When we first started the car, the G light was on. We found a return fuel line leak and fixed that. Then the G light was off. But the B stayed flashing. The car has been sitting for 8 years if this helps. Thanks in advance. The "G" is the alternator light. It goes off after you rev the engine. "B" is the brake light. If you release the emergency brake it should go off. It it doesn't it could be the reset button on the side of the master cylinder. This button is accessible behind the front left tire. Have you bleed the brakes lately or replaced the master cylinder? Either one of these could cause the brake light to flash even after the emergency brake is off, until you push the reset switch. Thank you, Steve. I didnt take the E brake off. I'll take a look at that tomorrow and see what happens. I appreciate it. (IMG:style_emoticons/default/smile.gif) |
Tom_T |
May 31 2016, 10:55 AM
Hi Ben,
You've got your answer above, & the "G" was an outdated use from the older 356 & VWs with generators, in the pre-alternator days. In addition to here & in our info section, the p914.com & Jeff Bowlsby's sites are excellent resources. for Gauges... ...also see the rest of site: http://p914.com/p914_gauges.htm Bowlsby's set: http://bowlsby.net/914/Classic/ http://bowlsby.net/914/CanAm/ http://bowlsby.net/914/WiringHarnesses/ (links to wiring diagrams at bottom also) http://bowlsby.net/914/PartsFS/ PB Anders is another great resource for the EFI, but I don't have that link handy, so maybe someone else can oblige? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/welcome.png) Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 8th May 2024 - 05:58 AM |
