Headlight motor, Relay bypass? |
DaveO90s4 |
Jun 2 2016, 02:35 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
One of my headlights has recently decided to not raise. I've been going through the Pelican fault diagnosis. I am pretty convinced now the motor and relay are good, but the problem is in the wiring.
With the relay removed I want to run alternative power to the relay socket to determine if the wiring fault us upstream or downstream from the relay. Can anyone please advise which of pins 30, 85, 86, 87 or 87A I either bridge or apply 12v to to do this test? Thanks Dave |
Lo-Fi Version | Time is now: 25th May 2024 - 09:07 PM |
