Now it gets weird..., My Rocker Arm Shafts are 20.6mm dia ???? |
Beebo Kanelle |
Jun 2 2016, 04:30 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
I went to the local VW/Porsche dealership to order the wavy spring washers and was told the were discontinued in 2009. Ok, no problem - just get on the interwebs for a p/n113-109-437 - (I got the p/n from the dealer). Received them and it turns out that the ID = 18.5mm and my old rocker arm shaft washers have a ID = 20.6mm ! I suppose that there are two types of rocker arm shafts ? Can anybody clarify my dilemma before I jump off a building? On top of everything else, its flooding down in Texas and I really want to get this solved. Thanks ! |
ejm |
Jun 2 2016, 05:26 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Those are for a VW Type 1. The part number you want is 021-109-435 which is NLA. I'm sure there are plenty of used ones out there so put an ad in the WTB section.
Lo-Fi Version | Time is now: 9th May 2024 - 01:57 AM |
