Fuel pressure and spark but won't run |
Groosh |
Jun 5 2016, 01:24 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
TheCabinetmaker |
Jun 5 2016, 01:28 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
An inline pressure gauge will show pressure in the system, but that doesn't mean fuel is getting past the injectors.
Groosh |
Jun 5 2016, 01:30 PM
An inline pressure gauge will show pressure in the system, but that doesn't mean fuel is getting past the injectors. Thanks. So if it firing on fluid the injectors are working but somehow I need to figure out if they are getting fuel. The fuel pressure gauge is off the right side rail. Any ideas on what to try next? |
emoze |
Jun 5 2016, 05:16 PM
Newbie Group: Members Posts: 19 Joined: 23-November 14 From: bakersfield Member No.: 18,149 Region Association: Southern California |
NO - if it fires on start fluid but won't run
- the injectors are either stuck or not pulsing - put a NOID Light on the injector plugs to narrow it down if it firing on fluid the injectors are working but somehow I need to figure out if they are getting fuel. The fuel pressure gauge is off the right side rail. Any ideas on what to try next? |
Lo-Fi Version | Time is now: 6th May 2024 - 11:44 AM |
