Fuel pressure and spark but won't run |
Groosh |
Jun 5 2016, 01:24 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
timothy_nd28 |
Jun 5 2016, 06:24 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I'm not sure if I can see the jumper from 88Y to 88Z, other than that it looks wired correctly.
With the ignition set to on and the ECU connector unplugged, do you get 12vdc at pin 10 to ground? What was the results with Rich's test with the pencil in the AFM? |
Groosh |
Jun 9 2016, 12:48 PM
I'm not sure if I can see the jumper from 88Y to 88Z, other than that it looks wired correctly. With the ignition set to on and the ECU connector unplugged, do you get 12vdc at pin 10 to ground? What was the results with Rich's test with the pencil in the AFM? The jump is there. I tried to unplug the ECU and test for 12vdc from any pin and did not seem to get any. I also bought a new relay which came today. It didn't help. I did notice that the fuel ground from the relay is hot. I traced it to the motor where it is grounded and get a volts from it. |
Lo-Fi Version | Time is now: 6th May 2024 - 05:24 AM |
