Fuel pressure and spark but won't run |
Groosh |
Jun 5 2016, 01:24 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
timothy_nd28 |
Jun 9 2016, 01:01 PM
Adding new parts just confounds the problem. Remove the fuel pump jumper and re-install the old dual relay.
When you tested for voltage on pin 10 of the ECU connector, was the ignition switch to on? If so, let's do one thing before continuing with further tests. On the ignition coil, there should be a single wire on the (+) side terminal. Remove this wire, and tape it off. It's bad for the ignition coil and points when doing tests with the ignition key set for on, but the engine not running. After the wire has been removed, we need to measure some voltages at the dual relay. With the meter set to DC, put the black lead on the negative battery post. Now with the red meter lead, probe pin 88z, then 88a and 88b. Report back what you see. This above test is done with the ignition key set to the "on or run" position. |
Lo-Fi Version | Time is now: 6th May 2024 - 09:54 AM |
