Fuel pressure and spark but won't run |
Groosh |
Jun 5 2016, 01:24 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
timothy_nd28 |
Jun 10 2016, 04:05 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Okay, use one of the jumper wires you just bought from Radio Shack and jump pin 86C on the dual relay to the positive battery terminal. Then recheck for voltages as I described in the earlier step.
Groosh |
Jun 11 2016, 06:53 AM
Okay, use one of the jumper wires you just bought from Radio Shack and jump pin 86C on the dual relay to the positive battery terminal. Then recheck for voltages as I described in the earlier step. 86c was already getting proper volts from the ignition switch in the "on" position so I didn't jump it. However I still get no other readings on 88a or 88b. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:35 AM |
