Fuel pressure and spark but won't run |
Groosh |
Jun 5 2016, 01:24 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
timothy_nd28 |
Oct 25 2016, 02:17 PM
Reattach wires to the ignition coil. Turn the engine so that the ignition points are in the closed position. Check the resistance from the negative terminal of the ignition coil to the negative battery post. You should again see 0 ohms.
If you see 0 ohms, switch the meter to measure DC volts. Briefly turn the key to on and measure the voltage between the + and - terminals of the ignition coil. You should see 12 volts. Turn off the ignition as soon as you get your measurement. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:33 PM |
