Fuel pressure and spark but won't run |
Groosh |
Jun 5 2016, 01:24 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
Groosh |
Oct 26 2016, 04:29 PM
So I've been working with Tim and he has been absolutely invaluable in helping me to diagnose and repair this wiring train wreck. Thank you to Tim and the 914World forum!
To help close the loop for others reading this post we, and by we I mean Tim, finally figured out that the condensor was shorting out. By cutting the wire to it we returned spark to the engine and it fired. The engine doesn't quite run but we are getting closer. |
Lo-Fi Version | Time is now: 6th May 2024 - 03:49 PM |
