CHT Gauge, Suggestions? |
sdoolin |
Jun 6 2016, 12:24 PM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
I have searched - cannot find much on aftermarket CHT Gauges.
I am building a 2056 that will run dual Dells - would like to install a quality CHT gauge and wondering what others have used. |
era vulgaris |
Jun 6 2016, 01:25 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I'm running the MGL Avionics Stratomaster Velocity TC2.
Digital, 4 channels, you can see the temp of every cylinder. User manual: http://www.stratomaster.eu/lignes/mgl/pdf/Vel_EN_TC2.pdf Might seem excessive to some, but it's been a massive aid in tuning and knowing that each cylinder is right on target. I also had an unexpected vac leak issue a couple months back, and looking at the gauge I knew immediately which cylinder had the problem. Here it is in my center console... Attached thumbnail(s) |
Mueller |
Jun 6 2016, 01:28 PM
I'm running the MGL Avionics Stratomaster Velocity TC2. Digital, 4 channels, you can see the temp of every cylinder. User manual: http://www.stratomaster.eu/lignes/mgl/pdf/Vel_EN_TC2.pdf Might seem excessive to some, but it's been a massive aid in tuning and knowing that each cylinder is right on target. I also had an unexpected vac leak issue a couple months back, and looking at the gauge I knew immediately which cylinder had the problem. I like that one, I was just going to ask about it when I saw it on the spruce site! |
Lo-Fi Version | Time is now: 17th May 2024 - 07:57 PM |
