CHT Gauge, Suggestions? |
sdoolin |
Jun 6 2016, 12:24 PM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
I have searched - cannot find much on aftermarket CHT Gauges.
I am building a 2056 that will run dual Dells - would like to install a quality CHT gauge and wondering what others have used. |
eyesright |
Aug 27 2016, 08:57 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I went with a VDO CHT along with an oil pressure and temp gauge on my stock 2.0L rebuild a couple of years and 40K miles ago. Looked good under the dash. It was accurate in that my head temps were exactly what Len Hoffman and Jake said they would be with the 9550 cam kit and HAM rebuilt heads. I checked it with an IR temp gun from HF by pulling the plug wire and flashing it around the spark plug area. Hard to find an ideal spot to read from as you are shooting the gun pretty much blind and there are lots of angles to reflect off of, but all the readings were reasonable and none were higher than the VDO gauge.
Lo-Fi Version | Time is now: 17th May 2024 - 09:31 PM |
