Why EFI?, maybe excellence was expected and they came as close as they could.. |
Gunn1 |
Jun 11 2016, 03:59 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Did Porsche eff up?
No they didn't eff up, they did the best they could with the new technology they had. It seems as though the technology was purchased by the folks at Bosch from the aviation component of Bendix. That said most Injection systems were originally good at idle and full open throttle, so primarily racing applications. So in there infancy not well suited for automobile applications. Been reading on different types of fuel delivery systems and their pro and cons. There are very few con's to todays EFI systems, there were however performance and reliability issues with the original designs. Even today Claims of increased HP, Fuel economy, drivability, reliability and so on....some still dispute how much these differences really mean. It appears the main thing EFI does extremely well over Carbs is in the pollution factor, or in this case the ability to pollute less. Carbs are a some what open system allowing hydro carbons to escape/vent in to our atmosphere even when the engine is at rest, where as the EFI is essentially a closed system releasing no vapors or gases unless the engine is running and those gases are then coming out of the tailpipe from the exhaust cycle. Many of the Guru's (about 5 to 1) prefer carburation. The above Statement isn't correct, although what confuses this OP is the sheer amount of photographic evidence on this site and others including evilbay and CL showing most engine compartments with Carbs installed. Many here have spent thousands on their cars, and what do you see when the lid is lifted? a Carburated engine..... So while my intentions will be keeping my cars in their stock or near stock form, with EFI, I cannot understand why so many Carburated cars. (Because its easy isn't an answer, because its simple isn't an answer and because its cheap isn't an answer) With this being the case, Did Porsche mess up when they went the EFI route with the 914? I do not believe they messed up, I believe they did the best they could with the available technology they had. Granted they did sort of use the end user as of a kind of a guinea pig/test bed, but what manufacturer doesn't in some way. WHY DID THEY DO IT????? I think that just as much as seeing the Ljet and Djet as a performance and platform to develop future EFI systems off of, Porsche and others also incorporated EFI into there products to show they were progressive company's in design and practicality. EFI, Unibody, Targa, Mid engine, four wheel disc, and many more attributes can be cited as Porsches View into the future. I would like to keep my car stock with the factory EFI, but increasingly getting more difficult to do with so little information backing it up. Above statement is also incorrect. In my case I think I am fortunate because I believe I have most the parts needed to reinstall the factory EFI's on all three of my cars. There is a plethora of info on both sides, but for now.... just for originalities sake, EFI will be the way I go. To those that added constructive comments and or facts to this thread... it is much appreciated...to those that took this thread as some sort of attack on their beliefs, or way to "clutter" the site, I can appreciate how you feel, but I just see those arguments as shutting down the free flow of ideas and the give and take of facts that get each of us to arrive at our own understanding of the information. |
Darren C |
Jun 13 2016, 09:31 AM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Very Nice info Jeff, but it doesn't show AFR which is what we need to compare eggs with eggs.
Maybe i can convince a fellow UK 914 FI owner to visit the same dyno and then we'll get a fair comparison. However at $150 an hour for dyno time it may prove a big ask. The data I just shared on here cost me 4 hours to obtain! We all know the real answer was emissions, my input to this thread was to make it a little more constructive. As regards HC's and NOx, in UK we have an emission tests each year. Older cars are exempt but I still get mine tested for kicks. The 914 on a carb conversion likes to run rich (hence less mpg when you convert) at 3%CO it runs but pops and farts. 4% CO and its fine, but would barely pass the modern UK emissions test. If you look at my graph the ideal AFR is 14.7:1, with carbs you will see they run between 13:1 and 9.5:1 in the jet range. Lower than a 115 main jet in a 2.0L carb car will get you close to 14.7:1 but you loose power & driveability (I tried it) Bosch state that most spark ignition engines develop their maximum power at air/fuel ratios of 12.5:1 - 14:1, maximum fuel economy at 16.2:1 - 17.6:1, and good load transitions from about 11:1 - 12.5:1. However, in practical applications, engine air/fuel ratios at maximum power are often richer than the quoted 12.5:1, This is the reason modern FI triumphs over carbs, because it can finitely vary the fueling to meet emissions. |
brant |
Jun 13 2016, 10:13 AM
914 Wizard Group: Members Posts: 11,631 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
We all know the real answer was emissions, my input to this thread was to make it a little more constructive. If you look at my graph the ideal AFR is 14.7:1, with carbs you will see they run between 13:1 and 9.5:1 in the jet range. Lower than a 115 main jet in a 2.0L carb car will get you close to 14.7:1 but you loose power & driveability (I tried it) Bosch state that most spark ignition engines develop their maximum power at air/fuel ratios of 12.5:1 - 14:1, maximum fuel economy at 16.2:1 - 17.6:1, and good load transitions from about 11:1 - 12.5:1. However, in practical applications, engine air/fuel ratios at maximum power are often richer than the quoted 12.5:1, ideal AFR for a 914 isn't 14.7 I think your own research shows that and a DJet tuned for a more rich mixture does help I've always done this to all of my F.I. cars 14.7 may be a goal in a laboratory... looking for emissions and theoretical burn but with an air cooled motor, other traits come into play such as intake charge cooling, max power, etc... in short, these cars like a more rich mixture under load (any time your not cruising at light throttle or idle) its long been my belief that the historic valve seat problem with stock 914/4 motors was due to the factory setting up the fuel injection too lean in an effort to improve emissions/fuel economy. empirically.. it is my observation that a lot less carb'd cars dropped valve seats due to running a more rich mixture and the cooling effects of a rich mixture on the heads brant |
Lo-Fi Version | Time is now: 31st May 2024 - 11:28 AM |
