Why EFI?, maybe excellence was expected and they came as close as they could.. |
Gunn1 |
Jun 11 2016, 03:59 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Did Porsche eff up?
No they didn't eff up, they did the best they could with the new technology they had. It seems as though the technology was purchased by the folks at Bosch from the aviation component of Bendix. That said most Injection systems were originally good at idle and full open throttle, so primarily racing applications. So in there infancy not well suited for automobile applications. Been reading on different types of fuel delivery systems and their pro and cons. There are very few con's to todays EFI systems, there were however performance and reliability issues with the original designs. Even today Claims of increased HP, Fuel economy, drivability, reliability and so on....some still dispute how much these differences really mean. It appears the main thing EFI does extremely well over Carbs is in the pollution factor, or in this case the ability to pollute less. Carbs are a some what open system allowing hydro carbons to escape/vent in to our atmosphere even when the engine is at rest, where as the EFI is essentially a closed system releasing no vapors or gases unless the engine is running and those gases are then coming out of the tailpipe from the exhaust cycle. Many of the Guru's (about 5 to 1) prefer carburation. The above Statement isn't correct, although what confuses this OP is the sheer amount of photographic evidence on this site and others including evilbay and CL showing most engine compartments with Carbs installed. Many here have spent thousands on their cars, and what do you see when the lid is lifted? a Carburated engine..... So while my intentions will be keeping my cars in their stock or near stock form, with EFI, I cannot understand why so many Carburated cars. (Because its easy isn't an answer, because its simple isn't an answer and because its cheap isn't an answer) With this being the case, Did Porsche mess up when they went the EFI route with the 914? I do not believe they messed up, I believe they did the best they could with the available technology they had. Granted they did sort of use the end user as of a kind of a guinea pig/test bed, but what manufacturer doesn't in some way. WHY DID THEY DO IT????? I think that just as much as seeing the Ljet and Djet as a performance and platform to develop future EFI systems off of, Porsche and others also incorporated EFI into there products to show they were progressive company's in design and practicality. EFI, Unibody, Targa, Mid engine, four wheel disc, and many more attributes can be cited as Porsches View into the future. I would like to keep my car stock with the factory EFI, but increasingly getting more difficult to do with so little information backing it up. Above statement is also incorrect. In my case I think I am fortunate because I believe I have most the parts needed to reinstall the factory EFI's on all three of my cars. There is a plethora of info on both sides, but for now.... just for originalities sake, EFI will be the way I go. To those that added constructive comments and or facts to this thread... it is much appreciated...to those that took this thread as some sort of attack on their beliefs, or way to "clutter" the site, I can appreciate how you feel, but I just see those arguments as shutting down the free flow of ideas and the give and take of facts that get each of us to arrive at our own understanding of the information. |
jd74914 |
Jun 13 2016, 05:11 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
FWIW: Using the factory measurements from 30 years ago (taken on who knows what equipment and averaged over a number of engines) and comparing to new measurements is really irrelevant. Heck, dynoing your car on one dyno then driving down the street to use another isn't even a good comparison. The only relevant comparison is against a single dyno because no two share the same calibration, etc. The only thing you are really guaranteed is repeat-ability, assuming you are using a quality device. When dynoing a car you really should be looking at the shape of the curve and relative comparisons between changes, not the peak HP/torque number
To me it's quite impressive [and lucky] that Darren's plots are anywhere close in magnitude to the factory numbers. Note that the Dyno Dynamics one that Darren is showing plots from is an extremely well-regarded eddy current device which is very repeatable. It can also hold engine speeds/loads constant to produce really nice curves unlike inertial dynos which are much more common (at least in the USA). It shouldn't be surprising that you can get better peak numbers on a carbed car than D- or L-jet car when just thinking about fuel mixing. Assuming both allow the exact same amount of fuel at a given time, fuel atomization from the carb will be much better. The Bosch fuel injector nozzle design is archaic compared to modern injectors. |
Darren C |
Jun 13 2016, 05:21 PM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
To me it's quite impressive [and lucky] that Darren's plots are anywhere close in magnitude to the factory numbers. Note that the Dyno Dynamics one that Darren is showing plots from is an extremely well-regarded eddy current device which is very repeatable. It can also hold engine speeds/loads constant to produce really nice curves unlike inertial dynos which are much more common (at least in the USA). Thanks Jim, That's probably why it's $150 an hour for roller time! I agree it was extremely lucky considering my car has 119,000 miles (1 owner with full history which shows no engine rebuild in it's life) Also it hadn't run for about 6-7 years before I bought it. All I did was pull the engine to change a couple of leaking oil seals and fit the carbs. All in all I am extremely pleased with this result. I bought it blind late one night off ebay, for a low price based on 6 thumbnail pictures and two bottles of wine. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1465860566.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1465860566.2.jpg) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:43 PM |
