PETRONIX RANT, Bosch & Petronix don't like each other |
ChrisFix |
Apr 7 2005, 09:30 PM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
I just checked the part number of the unit I installed two nights ago and it is 1847V and it fits perfectly. The unit height is such that its top is even with the top of the magnet ring. Since the top of the magnet ring is the below the bottom of the rotor there is no way for the rotor base to rub. The stocking label says "Fits Bosch 205, 009, and 050 Distributors". |
dmenche914 |
Apr 8 2005, 12:45 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Pertronix units are great, only time I had a dead one is when i killed it by cranking the car with no spark plugs hooked up (compression test) I should have pulled the coil hot wire first!!!! I have ran into one Bosch rotor that rubbed, on the sides of the rotor on one end. A quick file job, and it was repaired, subsequnet Bosch rotors did not have this problem! So the problem appears to be in the rotor diminsions, they were not even close to the same. Ran one Pertronix for near eight years, worked everytime, no more points adjustment, heaven!!! Also have ran Pertronix on my VW's, and friends cars. As mentioined, optical system are prone to dirt issues, the Pertronix does not, and is a clean install with near stock appearnace (no extrernal boxes). I think later Pertronix are made smaller, (can anyone confirm this???) if so, maybe all clearance issues are solved?? |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:16 PM |
