Tuesday, 23 September 2025 |
moorepower |
Member ![]() ![]() Group: Members Posts: 55 Joined: 9-May 15 From: eastern Nebraska Member No.: 18,718 Region Association: Upper MidWest ![]() |
How many are using factory points to trigger MSD? It eliminates almost all the burning of the points, because the only current is being used to trigger the ignition module.
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,702 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I use a MSD Billet Dizzy
veekry9 |
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada ![]() |
Why solid state is better:
https://www.picoauto.com/library/automotive...primary-voltage |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I done it several times, works just fine.
With a MSD it's just a switch and low volts so the points don't burn. |
moorepower |
I understand that solid state is better, but I plan on MSIII down the road and I am looking for a stop gap, until I do so. The points will control MSD like and optical trigger but not quite as accurately.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I have done it and it works fine.
Points don't burn but can get dirty and the rubbing block still wears. But since you need to lube the mechanical advance every now and then anyway you can clean and lube too. Jim |
veekry9 |
The coil doesn't care what type of switch stops the current,so sure,use the points if you like.
The waveform you get with the points tho,not as sharp,and erratic too. A stock coil will do for a stock distributor,no advantage there. Do put the distributor on a machine for a checkup,ensure the bearings are good and the drive gear has the correct backlash and endplay.The advance plates and vacuum must operate correctly for the model engine you have. Freshen up the high tension circuit,and use anti-seize on the plug threads. Do not use your tongue to test the ht cables. (IMG:style_emoticons/default/blink.gif) |
moorepower |
The coil doesn't care what type of switch stops the current,so sure,use the points if you like. The waveform you get with the points tho,not as sharp,and erratic too. A stock coil will do for a stock distributor,no advantage there. Do put the distributor on a machine for a checkup,ensure the bearings are good and the drive gear has the correct backlash and endplay.The advance plates and vacuum must operate correctly for the model engine you have. Freshen up the high tension circuit,and use anti-seize on the plug threads. Do not use your tongue to test the ht cables. (IMG:style_emoticons/default/blink.gif) Anti-seize should be used on every spark plug, including from the factory! |
veekry9 |
Drilling out and 'inserting' the head in situ:
Roll cylinder to tdc on intake stroke. Apply high vacuum,by venturi device.(not a vacuum cleaner!) Drill out remainder of plug to minor thd dia. Extract steel chips and electrodes magnetically. Inspect cylinder for chips visually,by borescope. Plug bottom end of hole with heavy grease or vaseline. Grease your drills. Drill out remainder of plug to pitch dia. Vacuum the grease plug out and replace. Attempt to remove remaining helix,use heat. Drill to major plug dia. Vacuum the grease plug out and replace. Drill to insert minor dia. Vacuum the grease plug out and replace. Tap insert thd. Inspect cylinder for chips visually,by borescope. Clean thd with acetone and or brake cleaner. Install insert with hitemp ceramic epoxy. Inspect cylinder for chips visually,by borescope. Apply high vacuum,by venturi device. Install new plug,with antisieze. Repeat for every broken plug. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/biggrin.gif) / |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I have a mallory unilite with optical pickup to drive my MSD.
The signal from that is a nice clean +12VDC square wave. My datalogger can read it directly for RPM while trying that with points will get you a fried microprocessor. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,930 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I have done it and it works fine. Points don't burn but can get dirty and the rubbing block still wears. But since you need to lube the mechanical advance every now and then anyway you can clean and lube too. Jim (IMG:style_emoticons/default/agree.gif) Key points there so why bother really,one step ahead then five back . |
Lo-Fi Version | Time is now: 23rd September 2025 - 01:31 AM |
