| Root_Werks |
Apr 7 2005, 01:33 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,998 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Whew! Well, since everything is in a temp file, I would try something like this from the directory in which your files reside:
mv -i *.php /home/temp/new_files/*.php3 Then you can: ls -l /home/temp/new_files/* > /home/temp/new_files/list.txt ls -l > list1.txt Compare the two list files to make sure nothing is missing. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
| bd1308 |
Apr 7 2005, 01:39 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
okay....did apt-get install php4 to get php4....figured it didnt work with php3 so i migth as well upgrade..done
dumped entire /phpBB2 to /trash....can't figure out how to delete whole non-empty dir's tho. next i'm going to print out my httpd.conf file and look through that to see if i left traces of php3 in there.... files are now needing to be named .php, but i was trying everything to see if any combo worked. nothing works rigth now, seems as if .php isnt recignized as an actual executable file to apache...but i dont see a module to load in httpd.conf |
| tat2dphreak |
Apr 7 2005, 01:43 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I don't think that mv will work the way you used it... if so, it doesn't work for me under HP UNIX.. I just set up a test to try it, using a copy of my sql directory and a temp dir under it... razor:MED:/home/wf6341/temp_sql-> mkdir test razor:MED:/home/wf6341/temp_sql-> mv -i *.sql ./temp/*.sq1 Usage: mv [-f] [-i] [-e warn|force|ignore] f1 f2 mv [-f] [-i] [-e warn|force|ignore] f1 ... fn d1 mv [-f] [-i] [-e warn|force|ignore] d1 d2 razor:MED:/home/wf6341/temp_sql-> |
| tat2dphreak |
Apr 7 2005, 01:44 PM
to delete whole non-empty directories... "rm -rf directory_name" be careful though... |
| Root_Werks |
Apr 7 2005, 01:50 PM
I'm just going off of memory. I have a unix emulator on my PC here at work I use sometimes for perl stuff, but haven't done much with the ksh in a few years. Written hundreds of ksh scripts on HP-UX boxes though. Ah the memories. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I think my emulator is running bash, that could be the difference there. |
| Gint |
Apr 7 2005, 08:07 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,108 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
This looks a lot like work!
From a bash shell command line (which is probably what you're running out of the box in Linux): ls *.php | awk -F. '{print $1}'|while read file; do mv $file.php $file.php3; done |
| Gint |
Apr 7 2005, 08:12 PM
rmdir or rm -r "directory name" But make sure you want to delete everying! Dude, if you're gonna keep this up, you need to invest in some books and learn to love man pages. |
| bd1308 |
Apr 8 2005, 12:39 AM
well i might just have to do that anyway, as i still don't feel confident in my php installation abilities.
| Gint |
Apr 8 2005, 08:59 AM
Just like everything else. Learn what you can from books. Then... Do it... try it... learn from your mistakes and build on the experience. |
Lo-Fi Version | Time is now: 11th June 2026 - 01:01 PM |
