914Rubber project kit - Headlight assembly restoration |
Mikey914 |
Jun 23 2016, 03:43 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looking at putting together a "project kit" that will allow you to take a weekend and completely restore your headlight area.
As we make several parts already, we have embarked in trying to get "everything" you need. Even the paint. The idea is that you can replace the bushings, and adjusters, and screws. Even including the chemicals you need to pre-treat the metal for rust resistance and matched paint. We have found a very good metal treatment that is not caustic and is pretty simple to use. We can get in quantity and break it into job size portions. Here is the preliminary fun I've had at testing these out. 1st the prospective assembly Attached thumbnail(s) Attached image(s) |
Mikey914 |
Jun 23 2016, 04:09 AM
So how close is this to stock?
You can see that the area on the top is almost identical to where I sprayed. So, I'm working on getting as many pieces of the puzzle to make it a simple process minimizing the trips out for odds and ends. Looking at all the bushings, adjuster screws, bases, and more. No price yet, but will be reasonable. So if interested let me know! Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:12 PM |
