Injectors clicking |
JPA914 |
Jun 23 2016, 07:37 PM
Member Group: Members Posts: 81 Joined: 30-June 15 From: Houston, TX Member No.: 18,905 Region Association: Southwest Region |
My '74 2.0 is running rough and I'm trying to rule out as many causes as I can. The car was running fine, but started idling low and acting like it was running on three cylinders a few minutes after being started. Now it acts this way right at startup. In trying to rule out the fuel system (I'm also looking into the ignition and injection, but that's a different thread), the following has been done:
Confirmed the fuel pressure is good at 29.5 psi The injectors were just tested and cleaned All new SS and rubber fuel lines (no kinks, no leaks) Cleaned fuel tank, brand new sock. If I stick a stethoscope on each injector while the engine's (barely) idling I can hear them all click at a regular rate. All click at the same volume without any dead spots in the sound. Can I rule out my trigger contacts because of this? I would imagine if the trigger contacts were a problem, I wouldn't hear certain injectors click at all, or perhaps there might be erratic clicking. Anybody know if that's the case? |
G e o r g e |
Jun 24 2016, 12:49 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
you list what has been done, is this since the problem started or before?
have you pulled 1 wire at a time to figure out what cylinder is not firing? |
mgp4591 |
Jun 24 2016, 01:11 PM
914 Guru Group: Members Posts: 5,372 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
you list what has been done, is this since the problem started or before? have you pulled 1 wire at a time to figure out what cylinder is not firing? Have you pulled one injector connection at a time to see if one is weak? The pintels on the injectors should sound the same most of the time but if you've got a bad connection because of an intermittent short in the connector it can cause the same issue. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:02 PM |
