GEX, have a opportunity, recommended or ????? |
Gunn1 |
Jun 25 2016, 06:00 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Have the Opportunity to purchase a GEX built 2.0 liter out of a 74 914 that was involved if a front end wreck.....may buy the complete car depending on $$$$.
The engine has a little over 2,000 miles on it and has the 2100 cc, Power Master upgrade - Pick up the additional HP to climb hills, Electronic Balancing - For longer life and a smooth running engine. Counterweighted Crankshaft - Allows engine to run smoother and ultimately to last longer. alt Maxi Oil Pump - Closer tolerances than a stock pump, provides added volume and increased oil pressure during low speed operation. high output alternator and the Compufire Ignition. The engine starts and runs fine, but no longer has any warranty on it. trying to come up with a value, because the guys wife is tried of looking at it and he just wants it gone. (think its the cause of many arguments) I haven't heard anything good or bad regarding GEX and their quality. Anyone have info on GEX? Thanks |
somd914 |
Jun 26 2016, 09:57 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
If you look at the prices GEX sells remanufactured engines for, you can't even begin to buy respectable parts and have typical machining performed for a DYI rebuild for those prices. That alone is a big red flag.
For me, a GEX engine is worth very little - nothing more than a questionable core. Good luck. |
Gunn1 |
Jun 26 2016, 10:08 AM
If you look at the prices GEX sells remanufactured engines for, you can't even begin to buy respectable parts and have typical machining performed for a DYI rebuild for those prices. That alone is a big red flag. For me, a GEX engine is worth very little - nothing more than a questionable core. Good luck. Primarily buying for the cumlitive amount of parts and goodies on the car. The engine is really secondary at this point. I see the value in the engine is in the Weber down drafts, external oil cooler, electronic ignition and other associated hard parts. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:03 PM |
