GEX, have a opportunity, recommended or ????? |
Gunn1 |
Jun 25 2016, 06:00 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Have the Opportunity to purchase a GEX built 2.0 liter out of a 74 914 that was involved if a front end wreck.....may buy the complete car depending on $$$$.
The engine has a little over 2,000 miles on it and has the 2100 cc, Power Master upgrade - Pick up the additional HP to climb hills, Electronic Balancing - For longer life and a smooth running engine. Counterweighted Crankshaft - Allows engine to run smoother and ultimately to last longer. alt Maxi Oil Pump - Closer tolerances than a stock pump, provides added volume and increased oil pressure during low speed operation. high output alternator and the Compufire Ignition. The engine starts and runs fine, but no longer has any warranty on it. trying to come up with a value, because the guys wife is tried of looking at it and he just wants it gone. (think its the cause of many arguments) I haven't heard anything good or bad regarding GEX and their quality. Anyone have info on GEX? Thanks |
Rand |
Jun 26 2016, 11:54 AM
As an aside, what's your most successful search phrase/keywords to search with? Searching GEX turns up nothing. Yet I know there are tons of threads about them going back well over a decade. I've tried "+GEX +engine*" but that brings up a lot of other unrelated results. I usually end up using google, with "site:914world.com" in front of the keywords. But I'd be interested in knowing what you've found works best.
Mueller |
Jun 26 2016, 01:07 PM
As an aside, what's your most successful search phrase/keywords to search with? Searching GEX turns up nothing. Yet I know there are tons of threads about them going back well over a decade. I've tried "+GEX +engine*" but that brings up a lot of other unrelated results. I usually end up using google, with "site:914world.com" in front of the keywords. But I'd be interested in knowing what you've found works best. OP has a tendency of not searching anywhere for anything 1st...he might not know what google is.... There was no reason to ask on 914world what a NACA duct is, none at all. Would it be a different definition here? No. I can see learning what a NACA duct is elsewhere and then asking how one has used one on a 914. That makes sense. |
Lo-Fi Version | Time is now: 21st May 2024 - 03:06 PM |
