orbit398 |
Member ![]() ![]() Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region ![]() |
I recently replaced my steering column blinker/headlight switch selector as the blinker portion was bad. I purchased a used one and the blinkers now work fine but it appears I have an issue with the low beam and high beam part of the switch. On my old switch, I just pulled the lever back to alternate between low beams and high beams. No issues there. Now, with the replacement switch, when I try to selected the high beam, the lights come on but once I release the lever, the go off. I can pull the lever again and the low beams come on. Pulling the lever again makes the high beams come on but once I release it, the high beams go out. Appears to be a faulty switch right?
Just want to confirm with others. |
Lo-Fi Version | Time is now: 11th July 2025 - 07:29 AM |
