Giant Air cooled Engine Parts.. FREE, Mountain View, CA Saw it on Craigs |
Brian Mifsud |
Jun 27 2016, 11:40 AM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Want to build a chassis twisting trans-axle snapping air cooled BIG FOUR?
Found these on Craigs in Mountain view.. FREE! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/first.gif) http://sfbay.craigslist.org/sby/zip/5651912344.html |
Jeff Hail |
Jun 28 2016, 12:00 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Want to build a chassis twisting trans-axle snapping air cooled BIG FOUR? Found these on Craigs in Mountain view.. FREE! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/first.gif) http://sfbay.craigslist.org/sby/zip/5651912344.html Looks like 470J series 6 cylinder barrels. 7.7 litres of dependable hp at 2500rpms. 125mm bore with a 101mm stroke. Very dependable motors with rotating exhaust valves. Those motors are long at 3 feet in length. Only drawback is they use a narrow rpm band of about 2400-2600 optimized for reliability. Rebuild every 2000 hours of run time. |
Brian Mifsud |
Jun 28 2016, 09:56 AM
Want to build a chassis twisting trans-axle snapping air cooled BIG FOUR? Found these on Craigs in Mountain view.. FREE! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/first.gif) http://sfbay.craigslist.org/sby/zip/5651912344.html Looks like 470J series 6 cylinder barrels. 7.7 litres of dependable hp at 2500rpms. 125mm bore with a 101mm stroke. Very dependable motors with rotating exhaust valves. Those motors are long at 3 feet in length. Only drawback is they use a narrow rpm band of about 2400-2600 optimized for reliability. Rebuild every 2000 hours of run time. I use a rule of thumb that MOST normally aspirated passenger car automotive engines make about 1 ft-lb of torque for each cubic inch of displacement. So for 7.7 liters at 60 cubic inches/liter... puts you at 462 ft-lbs... ignoring the limited power band.. the trans-axle would be a beast.... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 27th May 2024 - 02:43 PM |
