Plastic Tunnel Fuel Lines, I want to replace the 2 tunnel fuel lines in my 76 - 914 |
matchpoint |
Jun 28 2016, 04:58 PM
Newbie Group: Members Posts: 16 Joined: 19-March 16 From: Oregon Member No.: 19,783 Region Association: Pacific Northwest |
I have my 76 - 914 engine and fuel tank out of my car during my frame off restoration. I want to replace the 2 plastic/nylon fuel lines in the tunnel with an OE product and not use the stainless or mild steal fuel line. I want to go back original and after 40 years of service I want to replace the plastic lines. Looks like everyone says go stainless but I want to go with the OE plastic.
Does anyone have a part number of a replacement plastic/nylon tubing of the same size as the OE plastic tubing. I think it is 7MM OD size. Auto Atlanta told me to just blow out the OE plastic lines and don't waste your time replacing. Looks like an easy replacement while the car is apart and all I need to know is a P/N of a plastic/nylon fuel tubing I can get @ NAPA. Thanks |
Amphicar770 |
Jun 29 2016, 08:26 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
If you want to have original hoses because you think things like original motor oil are important, then that is your choice. Trying to argue that it is "better" because that is what came from the factory is nonsense.
Of course metal lines were available back in the 70's. So was gold wire. They did not choose plastic (or copper) because it was better but much more likely because Otto in accounting figured it would save $3 per car or Hans in manufacturing determined that it could be installed 3 seconds faster. Every cent counts in mass production. Yes, some aircraft use plastic lines but they are also subject to a level of annual and other inspections that go far beyond what even the most anal car owner is accustomed to. Every part has a lifespan rating and is replaced regardless of condition. If you do stick with plastic lines that is great. Just make sure to have a non-original fire extinguisher in your car. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 PM |
