Plastic Tunnel Fuel Lines, I want to replace the 2 tunnel fuel lines in my 76 - 914 |
matchpoint |
Jun 28 2016, 04:58 PM
Newbie Group: Members Posts: 16 Joined: 19-March 16 From: Oregon Member No.: 19,783 Region Association: Pacific Northwest |
I have my 76 - 914 engine and fuel tank out of my car during my frame off restoration. I want to replace the 2 plastic/nylon fuel lines in the tunnel with an OE product and not use the stainless or mild steal fuel line. I want to go back original and after 40 years of service I want to replace the plastic lines. Looks like everyone says go stainless but I want to go with the OE plastic.
Does anyone have a part number of a replacement plastic/nylon tubing of the same size as the OE plastic tubing. I think it is 7MM OD size. Auto Atlanta told me to just blow out the OE plastic lines and don't waste your time replacing. Looks like an easy replacement while the car is apart and all I need to know is a P/N of a plastic/nylon fuel tubing I can get @ NAPA. Thanks |
914_teener |
Jul 26 2016, 11:40 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The failure was the battery placement which caused the early failures. The 914 was a transition model and the decision to move the fuel pump was an easier decision logistically form an engineering prospective than moving the battery in my opinion. I never moved my pump for that reason and my lines are in good shape and not on the pressure side of the pump. Now the connections and rubber hoses in the injection loop in the engine compartment. I check those all the time. I sleep at night and drive my car alot....in really hot weather. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:01 PM |
