Struts That Go CLUNK In The Night, Curing a noisy front strut |
orthobiz |
Jun 28 2016, 06:15 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
So my daily driver developed an annoying clunk in the front driver side. A search here and on the Pelican board talks about a loose gland nut on the strut. Thought I'd just go through how I fixed it.
A couple of videos on YouTube: Jumping up and down on the fender With the wheel off My garage is extremely echogenic so it sounds much louder than it does on the road! Annoying nonetheless. Tools needed: 19mm socket 22mm socket Giant pliers Breaker Bar Torque Wrench Blue Locking Compound Jacks, jack stands Screwdriver, tamp or punch Mallet Paul |
Krieger |
Jun 29 2016, 08:04 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I had this problem too. Before I reassembled it I cut about 1 1/2" off the bottom of the upper cover so I can recheck the that nut from time to time without having to do this all over again. When the car is on the ground the cover is well over the gland nut.
orthobiz |
Jun 29 2016, 08:51 PM
I had this problem too. Before I reassembled it I cut about 1 1/2" off the bottom of the upper cover so I can recheck the that nut from time to time without having to do this all over again. When the car is on the ground the cover is well over the gland nut. Hmm, does "recheck" mean that you can tighten the nut from inside the wheel well without messing with the top nut in the trunk? Do you have a picture? Paul |
Lo-Fi Version | Time is now: 18th May 2024 - 03:26 AM |
