Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
stugray |
Jun 29 2016, 02:58 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
you can measure the valve travel without even taking the rockers off.
To actually get at the cam to change it, you have to split the case, now the "what should I replace?" comes down to 1 - your budget & 2 - what you find. In either order. You can inspect & measure all the 'pertinents' and decide if anything is worn. |
Lo-Fi Version | Time is now: 5th May 2024 - 09:58 PM |
