Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
r_towle |
Jun 29 2016, 06:47 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Mike,
Go to Elgin camshafts and look at what he sells. Lift ramp is most of what you can change . He has one that will work. Split the case, it will make drilling out the head studs easier to jig up. Plus, you cannot replace the camshaft without doing that . |
Lo-Fi Version | Time is now: 7th May 2024 - 08:31 AM |
