Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
Mueller |
Jun 30 2016, 10:57 AM
I called LN Engineering, they found the specs for the cam I have sitting around...
Lift: I .335 E .400 Duration: 290 I/E Duration @ .050: I 252 E 254 108 Lobe center. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:48 PM |
