Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
Mueller |
Jun 30 2016, 10:57 AM
I called LN Engineering, they found the specs for the cam I have sitting around...
Lift: I .335 E .400 Duration: 290 I/E Duration @ .050: I 252 E 254 108 Lobe center. |
stugray |
Jun 30 2016, 01:53 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I called LN Engineering, they found the specs for the cam I have sitting around... Lift: I .335 E .400 Duration: 290 I/E Duration @ .050: I 252 E 254 108 Lobe center. So those numbers seem a little odd. If that is lobe lift at the cam you will have approx. Ivalve = .460, Evalve = .520 at the valves Just as a datapoint, there are no webcams that are off much at all between Intake & exhaust advertised lift (although there is some). The 86b I run has advertise lift of .500/.500 at the valves with a similar duration as yours. The measured on mine for the 86b was I valve .475 Evalve .504 SO your cam is even a little more 'aggressive' than an 86b as far as intake/exhaust flow ratio is. Maybe that cam was destined for a big valve setup? |
Lo-Fi Version | Time is now: 28th April 2024 - 01:21 PM |
