Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
Mueller |
Jul 9 2016, 07:10 PM
Do I have to buy a new gear for the cam or can I remove the rivets on the original cam and the use bolts?
I saw a straight cut gear in the classifieds....too loud? What about cutting a groove in it? And if I do use my original cam gear worth making it adjustable able? |
jcd914 |
Jul 9 2016, 11:34 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Do I have to buy a new gear for the cam or can I remove the rivets on the original cam and the use bolts? I saw a straight cut gear in the classifieds....too loud? What about cutting a groove in it? And if I do use my original cam gear worth making it adjustable able? Send the cam over to Elgins and get it reground. |
Lo-Fi Version | Time is now: 29th April 2024 - 10:22 AM |
