Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
colingreene |
Jul 11 2016, 09:42 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
the right and best way to do modern ish fuel injection on the cheap would probably be Megasquirt.
Mueller |
Jul 11 2016, 10:26 PM
the right and best way to do modern ish fuel injection on the cheap would probably be Megasquirt. Just nervous with a fresh rebuild, what if it doesn't start right away or stalls too often? Will I screw up my new cam if it takes too long to get it running longer than 20 minutes or so? |
Lo-Fi Version | Time is now: 5th May 2024 - 05:12 AM |
