Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
McMark |
Nov 16 2017, 08:01 AM
I haven't worked with a MegaSquirt unit yet, so I haven't done a bunch of research on the nuance of adding ignition drivers. But with that coil you're only using a few milliamps to fire the coil, so you don't need beefy drivers. Essentially, any driver will work fine becuase the draw will be far below the safe rating. The BIP737 is something like 11A max. So that VW coil will be about 1% of that.
I always install the stand/yoke on the 3-4 (passenger) side of the engine case. |
Lo-Fi Version | Time is now: 7th May 2024 - 03:38 PM |
