Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
Mueller |
Jan 21 2018, 02:32 PM
Not sure if this qualifies for being cheap or resourceful. Lost a dowel pin and had a perfect sized HSS drill that I figured could be used. Drill still usable so no big deal.
Anyone using special engine break-in oil? https://type4store.com/products/sealants/jo...-12-quarts.html |
Lo-Fi Version | Time is now: 4th May 2024 - 04:34 AM |
