Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
G e o r g e |
Jun 30 2016, 04:50 PM
Dr Group: Members Posts: 1,904 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
a thread over on the samba Jake references a web cam 86a/86a +2 1/2 as the equal to the 9600.
looks like the 290 duration fit into their readings the + 2 1/2 must account for the intake and exhaust changes |
Mueller |
Jun 30 2016, 06:38 PM
a thread over on the samba Jake references a web cam 86a/86a +2 1/2 as the equal to the 9600. looks like the 290 duration fit into their readings the + 2 1/2 must account for the intake and exhaust changes Thanks, of course I am drawing a blank what "2 1/2" means. Advanced? |
Lo-Fi Version | Time is now: 28th March 2024 - 07:26 PM |
