Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
maf914 |
Jul 1 2016, 07:11 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
It looks like the cam specs are for a split duration cam, with the lift and duration for the exhaust valve increased to overcome the more restrictive exhaust port flow (relative to the better flowing intake port). At least that is what I recall from earlier tech threads from 914 World and ShopTalkForums.
Lo-Fi Version | Time is now: 29th March 2024 - 02:51 AM |
