Type IV rebuild / refresh thread. Nothing ground breaking., Changing cam in low mileage rebuit 1.8, making it a little hotter! Oh yea! |
Mueller |
Jun 29 2016, 02:47 PM
I popped the heads off in order to remove the broken exhaust studs (one per cylinder)
(I wrote broken head studs....I meant exhaust studs) Stock camshaft has some strange wear patterns on it which might be part of the previous owner problems with the motor. Cam will be a 9600 grind from Rabys old store Intake planned is stock L-Jet, however I can be swayed to install Megasquirt (plenum or ITB) since I already have the Megasquirt. Exhaust is older European Racing Header. |
Mueller |
Dec 25 2017, 02:14 PM
Finally, some work related to my 914...
Removed the main cylinder studs this morning. Noticed one of the smaller studs is bent pretty good. Will have to source another one. I plan to clean the engine case one more time, might be a little easier with the studs removed. The other side has a lot more oil caked onto it for some reason. |
Lo-Fi Version | Time is now: 26th April 2024 - 05:10 PM |
