Proper Rear Sway Bar Installation, Should links be up or down? |
jack20 |
Jul 2 2016, 01:20 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
When I bought my car the links to the sway bar were oriented down below the shock mounts. I have seen photos where the links were oriented above the shock mounts.
Which is correct? I'd take a photo but the rear suspension is completely out of the car. Thanks in advance. Jack |
toolguy |
Jul 2 2016, 07:45 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
like this, and you might want to check that the sway bar in rightside up also if someone screwed up the drop links
Attached thumbnail(s) |
Mark Henry |
Jul 2 2016, 10:09 PM
IIRC If the car is extremely lowered they will bang on the trunk floor and the reason some guys have mounted them upside down
jack20 |
Jul 3 2016, 05:53 PM
Thank you!
Lo-Fi Version | Time is now: 9th June 2024 - 08:04 PM |
