Fitting the rear shift lever into…..., the Ball cup bushing |
74ravenna |
Jul 3 2016, 01:35 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
Replacing the bushings on a side shift but I can't fit the Shift Lever into the Ball Cup Bushing (at the rear).
I've double checked to see if I bought the correct bushing and it appears that I have. I've applied a fair amount of force and it doesn't seem close to snapping in. A hard steel ball and a hard plastic cup with a smaller opening!!! Not a lot of give. Whats the trick? TIA Steve |
Mark Henry |
Jul 3 2016, 01:52 PM
Warm bushing in boiling water, put the bushing on the ball first. (IMG:style_emoticons/default/smile.gif)
Jul 3 2016, 01:56 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
you can drill a very small hole in the back of the bushing to release the air pressure. lube it with grease. push it in or tap with rubber mallet.
74ravenna |
Jul 3 2016, 02:37 PM
Ok, nice to have options!
Thanks Steve |
Lo-Fi Version | Time is now: 17th June 2024 - 02:33 AM |
