Looking for a 1970 914-6 Wiring Diagram, Can only find the 914-4 diagrams (posted below) |
db9146 |
Jul 6 2016, 01:41 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Guys,
I have looked through an electronic copy I have of the factory manuals and also a real hard copy and I can't find a wiring diagram for a "Model 70" 914-6....the earliest I can find is for a "Model 71" 914-4. Can someone please check your set to see if you find the same (is my set missing the 1970 -6 diagram)? I know Art Z sells the color ones but I need access sooner than that. Thanks. |
Kaeferfreund |
Jul 6 2016, 01:58 PM
Member Group: Members Posts: 122 Joined: 28-July 13 From: Germany Member No.: 16,172 Region Association: Germany |
Guys, I have looked through an electronic copy I have of the factory manuals and also a real hard copy and I can't find a wiring diagram for a "Model 70" 914-6....the earliest I can find is for a "Model 71". Can someone please check your set to see if you find the same (my set is missing the 1970 -6 diagram)? I know Art Z sells the color ones but I need access sooner than that. Thanks. What about these? http://www.pelicanparts.com/914/parts/Elec..._electrical.jpg http://www.pelicanparts.com/914/parts/Elec...ical_legend.jpg Perhaps it helps... |
JeffBowlsby |
Jul 6 2016, 02:01 PM
914 Wiring Harnesses Group: Members Posts: 8,470 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Guys, I have looked through an electronic copy I have of the factory manuals and also a real hard copy and I can't find a wiring diagram for a "Model 70" 914-6....the earliest I can find is for a "Model 71". Can someone please check your set to see if you find the same (my set is missing the 1970 -6 diagram)? I know Art Z sells the color ones but I need access sooner than that. Thanks. 1970 and 1971 /6 schematics are identical. |
db9146 |
Jul 6 2016, 02:06 PM
Kaeferfreund, thanks for the links....already tried those.
Jeff, thanks for the confirmation....the ones in the factory manuals are 914-4 diagrams they are NOT FOR A -6. |
Peashooter |
Jul 6 2016, 02:35 PM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
Those diagrams are for the 4 cyl. cars. There are some similarities, but not correct for a six. I have a factory diagram, but it is so tiny it is hard to read and there are no wire colors on it, only sizes. I got a regular diagram(not color) from Art and it helped a lot.
stugray |
Jul 6 2016, 03:01 PM
I believe that this is the factory electrical manual for the 914-6.
I didnt download the whole thing to see, but the one for the 914-4 is legit: http://www.manualslib.com/products/Porsche...-6-3965278.html |
Perry Kiehl Clone |
Jul 6 2016, 04:23 PM
Unregistered |
The only color wiring diagram that I know about is Art's. What do you need to know about?
Mike Bellis |
Jul 6 2016, 06:26 PM
db9146 |
Jul 6 2016, 06:38 PM
Mike,
Thanks...I found that on the Pelican site over the weekend. Unfortunately, it doesn't enlarge very well. I want to know what manual "Electrical 13-2" comes from....its not in the factory 914 manuals. Anyone know? |
Lo-Fi Version | Time is now: 19th April 2024 - 07:16 PM |
