WOT: Mercedes K-Jetronic Help, Posting here because I know you guys know this stuff |
ThePaintedMan |
Jul 7 2016, 07:36 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
In an attempt to broaden my horizons as a diagnostician (and mostly because I need the money to keep the lights on), I'm helping a neighbor with his 1983 Mecedes 380SL. The car is a V8 with the Bosch K-Jetronic mechanical injection system, similar to the CIS on the 911.
I have studied the system to have a pretty good understanding of how it works, or at least the physics behind it. What I'm dealing with at the moment is a no-idle condition, both cold and hot, but it's far worse when cold. The neighbor claimed he can get it to run by dumping gas in the air sensor plate orifice for a few minutes and then if he jams a screw driver in the linkage, it'll idle (poorly). Above idle, it revs up and down pretty well. Here's the data I have gathered: - All 8 injectors are brand new - The Idle Air Valve has been replaced relatively recently - The Idle Air Control Unit appears to have been replaced recently A couple things - if I "prime" the fuel distributor by pressing down the sensor plate, I can get the car to fire to life right away, but it will not idle. If I have someone else start the car, but I hold the sensor plate just barely down, it will idle almost perfectly. To me, this tells me that the car isn't getting enough air, or fuel at idle (duh), indicating that the idle control system itself isn't functioning. Here are a couple things I still need to check: -The functioning of the Overload protection relay (OVP) which I heard has an impact on the idle system -Need to test for voltage at the idle air control valve (I think it's supposed to be 12+ volts) -Need to test for voltage at the cold start injector (but my understanding is this is only functional when the car is being cranked anyway) Otherwise, I'm open to your troubleshooting suggestions and/or workflow. (IMG:style_emoticons/default/pray.gif) Thanks! -G |
Mueller |
Jul 7 2016, 07:49 AM
Make sure the boot has no leaks. Had this issue with my Audi years ago.
dlee6204 |
Jul 7 2016, 08:01 AM
ThePaintedMan |
Jul 7 2016, 08:54 AM
10-4. To be honest, I can't even figure out what the bottom of the intake even looks like - I.e., how the throttle body lets air into each intake runner. I haven't been able to find a good diagram with the air sensor and fuel distributor removed to get an idea how it all works.
Mueller |
Jul 7 2016, 09:08 AM
10-4. To be honest, I can't even figure out what the bottom of the intake even looks like - I.e., how the throttle body lets air into each intake runner. I haven't been able to find a good diagram with the air sensor and fuel distributor removed to get an idea how it all works. CIS discussion and pic for 380SL I think Pelican Parts has a decent Mercedes forum, not sure what other Mercedes forums are good (I need to, ours is almost out of warranty (IMG:style_emoticons/default/sad.gif) ) |
Shadowfax |
Jul 7 2016, 09:18 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Had K-jet on my '82 E21 323i. Miss that car...
Anyway, agree with the others on air leaks but could also be a improperly adjusted throttle plate. This link is for Volvos but has good troubleshooting. |
rgalla9146 |
Jul 7 2016, 11:07 AM
You need to check the boot between the sensor plate and throttle.
Beyond that you need to know system pressure and control pressure which is measured with a special fuel pressure gauge. Fuel pressure regulators are an issue as well. I have no experience with the system as used by MB. I was used on 911s from 73.5 to 1983 |
infraredcalvin |
Jul 7 2016, 11:54 PM
Distracted Member Group: Members Posts: 1,509 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
flyer86d |
Jul 8 2016, 04:01 AM
Member Group: Members Posts: 422 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Check the cold start injector for voltage and if you have that, pull the injector out and see if it sprays. You need that spray of fuel to get the engine to fire and pull the mass flow sensor plate open to supply fuel to the injectors. Also, I have seen idle air valves seize. Pull it out and see if it swings freely.
Charlie |
rick 918-S |
Jul 8 2016, 04:32 AM
Hey nice rack! -Celette Group: Members Posts: 20,423 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
You need to check the boot between the sensor plate and throttle. Beyond that you need to know system pressure and control pressure which is measured with a special fuel pressure gauge. Fuel pressure regulators are an issue as well. I have no experience with the system as used by MB. I was used on 911s from 73.5 to 1983 (IMG:style_emoticons/default/agree.gif) check for leaks. Don't mess with anything until you know what the fuel system pressure is. No short cuts. Don't mess with the sensor plate adjustment if you haven't checked the system at the WUR. Could be a bad fuel pump. |
Jul 8 2016, 03:04 PM
System pressure is the primary control signal for K-jet. It is critical that you know what the pressure is.
--DD |
Lo-Fi Version | Time is now: 26th April 2024 - 11:10 PM |
