Tach signal and EFI, Megasquirters and Subaru converters please read... |
falcor75 |
Jul 25 2016, 01:39 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I'm running my 2.0 four cylinder with an aftermarket ECU.
In the settings for the tach signal I've selected 12v, 50% duty and this worked fine for a few months of testing. The day before my dyno session the tach started behaving wierdly. It would start up fine but after a little bit of running it would settle between 3k-4k rpm. Revving the engine would momentarily get it back to normal but after a few seconds at constant rpm it would return to its new favorite position. Any ideas what could be causing this? |
Series9 |
Jul 25 2016, 06:52 AM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
I'm running my 2.0 four cylinder with an aftermarket ECU. In the settings for the tach signal I've selected 12v, 50% duty and this worked fine for a few months of testing. The day before my dyno session the tach started behaving wierdly. It would start up fine but after a little bit of running it would settle between 3k-4k rpm. Revving the engine would momentarily get it back to normal but after a few seconds at constant rpm it would return to its new favorite position. Any ideas what could be causing this? I'm going to say a high-resistance terminal is the problem. Some of the stock tachs work with modern ECUs, but many require an amplifier. The computer signal is really a bit weak to run an old tach. The easiest solution is to grab an Autometer tach from your local store. I have found a few wraps of gaffer's tape will create a nice friction-fit. Otherwise, the installation of a signal amplifier is also easy. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:57 PM |
