making a KEP clutch work, any tricks? |
worn |
Jul 26 2016, 11:42 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Well, I was almost ready to lower the car off jack stands and since I installed the axles I figured it was time to start the car just to make the wheels turn. With the motor off the gears all shift. I have spent a lot of time aligning shifter forks and getting the linkage right. But with the engine spinning I get a very disagreeable noise when I try to shift with the clutch pedal down.
It is a KEP 3.2 to 901 conversion in which I received a starter ring, pressure plate clutch disc and throwout bearing. I bought it used from someone on the board (cannot currently find who) so I really do not know what I have for certain. At install it all went together well, but the clutch disk, pressure plate and bearing all seemed to be stock-sourced parts. Are there any tricks I should be thinking about. I would prefer to leave the tranny where I put it, but obviously that may not be possible. So even if it has to come off I am seeking advice. Also if anyone has info on what I should have in the package that could help. Not saying someone sent me the wrong thing: saying I can make a mess of a parts bin that I have. helppp... |
Mark Henry |
Jul 26 2016, 02:36 PM
Was the stock flywheel flat one like a 3.0?
For the 3.0 the "starter ring" is more than just a 911 starter ring, it's almost 1" thick, so it's more of an adaptor ring. The 911 starter ring is thin maybe 3/16". The ring in Andy's pic is thick. Did you take a pic of it before you installed it? The ring I made for my conversion. (IMG:http://www.914world.com/bbs2/uploads/post-26-1391891641.jpg) |
SirAndy |
Jul 26 2016, 02:38 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Was the stock flywheel flat one like a 3.0? My flywheel before the clutch and ringgear install ... (IMG:http://www.914world.com/bbs2/uploads/post-179-1181192469.jpg) |
Lo-Fi Version | Time is now: 19th May 2024 - 11:33 PM |
